Failed to register with the HAF library.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Failed to register with the HAF library. Socket index = %p1%
| Name | Type |
| p1 | uInt32 |
